HVAC Filter Replacement
  1. HVAC Filter Replacement, Filter: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Observe your air conditioning vent. If the filter appears to be dirty or damaged, then it is time to change it.
  2. HVAC Filter Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws on the vent cover. There should be a minimum of 4 screws in each corner of the vent.
    • The screws in this vent are phillips hex head screws that are 1 3/4 in. long.
  3. HVAC Filter Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab a screwdriver with a hex head attachment to remove the screws. Grab the screwdriver and place it on the head of the screw. Twist in a counterclockwise motion until the screw is removed. Repeat for every screw.
  4. HVAC Filter Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the vent cover to access the ventilation filter.
  5. HVAC Filter Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Optional: Put on a latex glove on the hand that you will use to remove the filter.
  6. HVAC Filter Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the filter carefully.
    • Make sure to remove it slowly so that the dust does not come of it.
  7. HVAC Filter Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Dispose of the old filter in a waste bin.
  8. HVAC Filter Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Buy a Honeywell Air Filter from Home Depot and make sure to buy the filter with the correct dimensions.
    • The dimensions for filters will vary depending on the dimensions of the vent.
    • In this case, my vent was 14x25x1 and thus needed a filter with the same dimensions.
  9. HVAC Filter Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the new filter into the vent opening. Make sure that it is facing the right direction.
    • There will be an arrow on the side of the filter showing which way to place it.
  10. HVAC Filter Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place vent cover.
  11. HVAC Filter Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the same screws that were taken out at Step 3 and use them to secure the vent cover.
    • Place the screwdriver on the head of the screw and twist in a clockwise motion until screw is secure.
    • Repeat for every screw.
  12. HVAC Filter Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn on your air conditioner to make sure the filter does not move.
    • If the filter does not move, then you have successfully replaced the filter of your air conditioner.
Anthony Estevez
crwdns2935283:010/20/23crwdne2935283:0
67 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 2-1, Briggs Fall 2023 crwdns2935289:0CSU Los Angeles, Team 2-1, Briggs Fall 2023crwdne2935289:0
CSULA-BRIGGS-F23S2G1
crwdns2942667:0crwdne2942667:0 268
