This guide is for filter replacement of air conditioning. This replacement is needed to allow proper airflow while preventing particles from leaving the vent. I purchased the filter in Home Depot. Make sure to know the dimensions of the vent opening as there are filters with different dimensions. Additionally, there are 5 categories of filters and are rated by how effective they are. I bought a filter with a score of 9 out of 10 so choose one that meets your budget.
Observe your air conditioning vent. If the filter appears to be dirty or damaged, then it is time to change it.
Remove the screws on the vent cover. There should be a minimum of 4 screws in each corner of the vent.
Grab a screwdriver with a hex head attachment to remove the screws. Grab the screwdriver and place it on the head of the screw. Twist in a counterclockwise motion until the screw is removed. Repeat for every screw.
Remove the vent cover to access the ventilation filter.
Dispose of the old filter in a waste bin.
Buy a Honeywell Air Filter from Home Depot and make sure to buy the filter with the correct dimensions.
The dimensions for filters will vary depending on the dimensions of the vent.
Place the new filter into the vent opening. Make sure that it is facing the right direction.
Grab the same screws that were taken out at Step 3 and use them to secure the vent cover.
Place the screwdriver on the head of the screw and twist in a clockwise motion until screw is secure.
Turn on your air conditioner to make sure the filter does not move.
