Takes you through the steps to install the speakers.
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
crwdns2935267:0crwdne2935267:0Spudger$3.99
Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
Work the spudger around the edges of the camera cover until it comes off.
crwdns2935267:0crwdne2935267:0T5 Torx Screwdriver$5.49
Remove the four 6 mm screws with the T5 Torx screwdriver.
Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
Work the tool around the edges until all the clips release.
Once all the clips are open, remove the inner panel from the phone.
Use the plastic opening tool to disconnect the speaker connections.
