This guide will explain how to install / remove the LCD screen from the HTC Wizard 200.
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
crwdns2935267:0crwdne2935267:0Spudger$3.99
Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
Work the spudger around the edges of the camera cover until it comes off.
crwdns2935267:0crwdne2935267:0T5 Torx Screwdriver$5.49
Remove the four 6 mm screws with the T5 Torx screwdriver.
Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
Work the tool around the edges until all the clips release.
Once all the clips are open, remove the inner panel from the phone.
Use the spudger to pry the camera off.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, flip the connector latch away from the motherboard.
Detach the flexible connection from under the connector latch.
Slide the keyboard into the open position.
Lift the motherboard out of the case using the spudger.
Expose the underside of the motherboard using your hands.
Remove the flexible connection from the motherboard.
Remove the four 5mm screws with the T5 Torx screwdriver.
Remove the keyboard slider from the main body.
Use the T5 Torx screwdriver to remove four 5mm screws that secure the back of the screen casing.
Insert the plastic opening tool between the front panel and the rear panel and pry open to reach the screen.
Once the rear panel is loose, lift it off of the front panel.
The flexible connection will pop loose.
Unscrew the two 3mm phillips #0 screws from the bottom of the device that secure the rigid flex board to the screen panel.
Unscrew the two 3mm phillips #0 screws from the top of the device that secure the rigid flex board to the screen panel.
Unhinge the flexible connection and use the tweezers to disconnect.
Now that the rigid flex board is loose, remove it from the screen.
Simply pull out the loose screen.
