HTC Wizard 200 Keyboard Slider Replacement
  1. HTC Wizard 200 Keyboard Slider Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Keyboard Slider Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To expose the battery, remove the outer case with your fingernail.
    • Remove the battery by pulling the black tab.
  2. HTC Wizard 200 Keyboard Slider Replacement, Back Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Spudger
    $3.99
    • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
  3. HTC Wizard 200 Keyboard Slider Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Keyboard Slider Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Spudger
    $3.99
    • Work the spudger around the edges of the camera cover until it comes off.
  4. HTC Wizard 200 Keyboard Slider Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Keyboard Slider Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    T5 Torx Screwdriver
    $5.49
    • Remove the four 6 mm screws with the T5 Torx screwdriver.
    • One of the screws is under the "void" sticker.
  5. HTC Wizard 200 Keyboard Slider Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Wizard 200 Keyboard Slider Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Wizard 200 Keyboard Slider Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
    • Work the tool around the edges until all the clips release.
  6. HTC Wizard 200 Keyboard Slider Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Keyboard Slider Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once all the clips are open, remove the inner panel from the phone.
  7. HTC Wizard 200 Keyboard Slider Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Spudger
    $3.99
    • Use the spudger to pry the camera off.
  8. HTC Wizard 200 Keyboard Slider Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Keyboard Slider Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, flip the connector latch away from the motherboard.
    • Detach the flexible connection from under the connector latch.
  9. HTC Wizard 200 Keyboard Slider Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the keyboard into the open position.
  10. HTC Wizard 200 Keyboard Slider Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Keyboard Slider Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Spudger
    $3.99
    • Lift the motherboard out of the case using the spudger.
    • Expose the underside of the motherboard using your hands.
  11. HTC Wizard 200 Keyboard Slider Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Keyboard Slider Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the flexible connection from the motherboard.
    • Caution: Removing the connection too fast may cause damage to the connection and cables.
  12. HTC Wizard 200 Keyboard Slider Replacement, Keyboard Slider: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Wizard 200 Keyboard Slider Replacement, Keyboard Slider: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Wizard 200 Keyboard Slider Replacement, Keyboard Slider: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    T5 Torx Screwdriver
    $5.49
    • Remove the four 5mm screws with the T5 Torx screwdriver.
    • Remove the keyboard slider from the main body.
Kyle Champ
crwdns2935283:010/03/11crwdne2935283:0
225 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-27, Maness Fall 2011 crwdns2935289:0Cal Poly, Team 20-27, Maness Fall 2011crwdne2935289:0
CPSU-MANESS-F11S20G27
crwdns2942667:0crwdne2942667:0 977
