HTC Wizard 200 Front Buttons Replacement
crwdns2869540:0crwdne2869540:0: 1,1 тыс.
3
17
90
1 051
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: crwdns2931273:0crwdne2931273:0
This guide takes you through the steps to install the front panel buttons.
    1. HTC Wizard 200 Front Buttons Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Front Buttons Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • To expose the battery, remove the outer case with your fingernail.
      • Remove the battery by pulling the black tab.
    1. HTC Wizard 200 Front Buttons Replacement, Back Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      Spudger
      $3.99
      • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
    2. HTC Wizard 200 Front Buttons Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Front Buttons Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      Spudger
      $3.99
      • Work the spudger around the edges of the camera cover until it comes off.
    3. HTC Wizard 200 Front Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Front Buttons Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      T5 Torx Screwdriver
      $5.49
      • Remove the four 6 mm screws with the T5 Torx screwdriver.
      • One of the screws is under the "void" sticker.
    4. HTC Wizard 200 Front Buttons Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Wizard 200 Front Buttons Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Wizard 200 Front Buttons Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
      • Work the tool around the edges until all the clips release.
    5. HTC Wizard 200 Front Buttons Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Front Buttons Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once all the clips are open, remove the inner panel from the phone.
    1. HTC Wizard 200 Front Buttons Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      Spudger
      $3.99
      • Use the spudger to pry the camera off.
    2. HTC Wizard 200 Front Buttons Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Front Buttons Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using tweezers, flip the connector latch away from the motherboard.
      • Detach the flexible connection from under the connector latch.
    3. HTC Wizard 200 Front Buttons Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the keyboard into the open position.
    4. HTC Wizard 200 Front Buttons Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Front Buttons Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      Spudger
      $3.99
      • Lift the motherboard out of the case using the spudger.
      • Expose the underside of the motherboard using your hands.
    5. HTC Wizard 200 Front Buttons Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Front Buttons Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the flexible connection from the motherboard.
      • Caution: Removing the connection too fast may cause damage to the connection and cables.
    1. HTC Wizard 200 Front Buttons Replacement, Keyboard Slider: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Wizard 200 Front Buttons Replacement, Keyboard Slider: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Wizard 200 Front Buttons Replacement, Keyboard Slider: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      T5 Torx Screwdriver
      $5.49
      • Remove the four 5mm screws with the T5 Torx screwdriver.
      • Remove the keyboard slider from the main body.
    1. HTC Wizard 200 Front Buttons Replacement, Screen Cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Front Buttons Replacement, Screen Cover: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the T5 Torx screwdriver to remove four 5mm screws that secure the back of the screen casing.
    2. HTC Wizard 200 Front Buttons Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Front Buttons Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the plastic opening tool between the front panel and the rear panel and pry open to reach the screen.
    3. HTC Wizard 200 Front Buttons Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Front Buttons Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once the rear panel is loose, lift it off of the front panel.
      • The flexible connection will pop loose.
    4. HTC Wizard 200 Front Buttons Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Device rotated 90 degrees CCW.
      • Remove the yellow anti-static tape.
    5. HTC Wizard 200 Front Buttons Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Front Buttons Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the two 3mm phillips #0 screws from the bottom of the device that secure the rigid flex board to the screen panel.
    6. HTC Wizard 200 Front Buttons Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Device rotated 180 degrees CW.
      • Unscrew the two 3mm Phillips #0 screws from the top of the device that secure the rigid flex board to the screen panel.
    7. HTC Wizard 200 Front Buttons Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unhinge the flexible connection and use the tweezers to disconnect.
    8. HTC Wizard 200 Front Buttons Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Now that the rigid flex board is loose, remove it from the screen.
    1. HTC Wizard 200 Front Buttons Replacement, LCD Screen: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Front Buttons Replacement, LCD Screen: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Simply pull out the loose screen.
    1. HTC Wizard 200 Front Buttons Replacement, Front Buttons: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Wizard 200 Front Buttons Replacement, Front Buttons: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull out the front button panel.
Kyle Champ
crwdns2935283:010/03/11crwdne2935283:0
225 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-27, Maness Fall 2011 crwdns2935289:0Cal Poly, Team 20-27, Maness Fall 2011crwdne2935289:0
CPSU-MANESS-F11S20G27
crwdns2935297:0144crwdne2935297:0
crwdns2936753:030crwdne2936753:0 90
crwdns2959996:0crwdne2959996:0 1,051
