Make sure you complete the previous guides.
Power the phone off.
Use your thumb to gently press downward and away from the camera to remove the battery cover.
Pull on the plastic tab to release the battery.
Use a plastic opening tool to remove the camera cover.
Lift the camera cover off of the phone.
Remove the stylus from the phone.
Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
Lift the back case off completely.
Grip the speaker connector with your thumb and finger and gently pull up.
Repeat for 2nd speaker.
Locate the camera and pry off with the plastic opening tool or spudger.
Remove the 3.4 mm black screw with the Phillips #000 screwdriver.
Remove the plastic tape to reveal the connector.
Use your finger or plastic opening tool to flip the connector and release the cable.
Use the plastic opening tool to carefully lift the motherboard off one corner at a time.
If the motherboard is not easily removed by pulling, then lift one side of the motherboard until you can see the attached cable. Then use the plastic opening tool to detach the cable from the motherboard.
