HTC Windows Phone 8S Display Assembly Replacement
crwdns2936621:0crwdne2936621:0
  1. HTC Windows Phone 8S Display Assembly Replacement, Loudspeaker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement, Loudspeaker: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement, Loudspeaker: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Switch off the phone.
    • Remove the SIM / memory card cover.
    • Remove any SIM and memory cards.
    • Use screwdriver torx T5 and unscrew the two screws at the bottom of the battery / back cover.
  2. HTC Windows Phone 8S Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic tool and slowly separate the back cover.
    • The loudspeaker is inside on the back cover.
  3. HTC Windows Phone 8S Display Assembly Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement, Battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #0 screwdriver and remove the 4x silver screws.
    • With a plastic tool carefully separate the battery from the logic board.
  4. HTC Windows Phone 8S Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery connector is under the middle frame. Remove it and disconnect the battery.
    • Model: BM59100 / 3,8VDC / 1700mAh
  5. HTC Windows Phone 8S Display Assembly Replacement, Flex Cables: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement, Flex Cables: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement, Flex Cables: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the USB dock connector metal plate.
    • Open flex cable connectors:
    • LCD display flex cable
    • Menu buttons flex cable
    • Volume buttons flex cable
    • Touch screen flex cable
    • Power button flex cable
    • Pick up the vibrating motor and take out all flex cables except the LCD display flex cable.
  6. HTC Windows Phone 8S Display Assembly Replacement, Logic Board Removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement, Logic Board Removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement, Logic Board Removal: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The logic board is secured to the display frame by two locking clips.
    • Use a plastic tool to release it.
    • Now remove the LCD display flex cable from its connector.
  7. HTC Windows Phone 8S Display Assembly Replacement, Logic Board / Main Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement, Logic Board / Main Board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • HTC Windows Phone 8S Logic Board.
  8. HTC Windows Phone 8S Display Assembly Replacement, Display Assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement, Display Assembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement, Display Assembly: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert wisdom here.
  9. HTC Windows Phone 8S Display Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Check your spare part for the menu buttons flex cable.
    • Remove the flex cable from the old touch screen if you need.
  10. HTC Windows Phone 8S Display Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Clean the frame from the old adhesive tape.
    • Install new adhesive tape.
    • It would be better if you use adhesive sticker ready for the model.
    • Install the display assembly.
  11. HTC Windows Phone 8S Display Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Windows Phone 8S Display Assembly Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Prepare the menu buttons and LCD display flex cables.
    • Start with reassembling.
    • Did you do it successfully?
ZFix
crwdns2935283:012/09/13crwdne2935283:0
194,598 crwdns2915208:0crwdne2915208:0
crwdns2935297:0330crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0327crwdne2931471:0
crwdns2935297:01,702crwdne2935297:0
crwdns2942667:0crwdne2942667:0 2,824
