Building upon basic teardown guides, this guide will allow you to replace the camera inside your phone in about 20 minutes.
Remove the back cover (not pictured) to your phone.
To remove the battery, place your thumb beneath the tab and begin to lift.
Pinching the battery, lift up at an angle from the bottom of the phone.
Use a T6 screwdriver to remove the four screws on the rear plate of the HTC Touch Pro.
Next, remove the casing that covers the camera and motherboard.
Insert your spudger along the slit between the keyboard and the external casing. Pry open as shown.
Remove the keyboard ribbon from the motherboard. To do this, simply grasp the ribbon at its base and pry it up at an angle. The ribbon has a metal end that is easily removed from the motherboard.
Using a Phillips Head size 0 screwdriver, remove the 3 screws holding in the battery compartment.
Remove the ribbon covering the battery compartment by pinching it at the base and lifting.
The camera is only held in by one connection to the motherboard and some tape.
Remove its connection to motherboard in the same way that you've removed such connections in the past.
Peel the tape holding it in place.
After that it will be free to remove and replace as necessary.
