To replace keyboard.
First, gently press on the back plate and push down toward the camera.
Use your finger to lift up the edge of the battery.
Remove the 4 screws using the T6 screw driver.
Lift the plastic cover near the memory card slot.
Remove the two Phillips #00 screws from the backside of the screen.
Insert a spudger or a plastic opening tool into the seam on the side of the phone.
Gently pry apart the two halves of the phone.
Gently unplug the connectors.
Remove the screws with a 00 Phillips-head screwdriver.
Gently lift the motherboard up using a nylon spudger.
Remove the 4 screws circled in red using a 00 Phillips-head screwdriver.
