HTC Touch Pro 2 Housing Replacement
  1. HTC Touch Pro 2 Housing Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Touch Pro 2 Housing Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Touch Pro 2 Housing Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply pressure and slide upward to remove back cover.
    • Lift the back cover up away from the phone.
  2. HTC Touch Pro 2 Housing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Touch Pro 2 Housing Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift battery upward on the upper right-hand side to remove it.
    • Check the battery to make sure there's no bent corners
  3. HTC Touch Pro 2 Housing Replacement, Housing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Touch Pro 2 Housing Replacement, Housing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a T5 screwdriver, remove the four screws in corners as shown.
    • Lift the top portion of the rear case.
    • There is a ribbon attached on the back of this part that requires caution to remove.
  4. HTC Touch Pro 2 Housing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Touch Pro 2 Housing Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Touch Pro 2 Housing Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using an IfixIt Plastic Tool, detach the plastic casing from the keyboard. This may require some force.
    • Using a spudger or other thin tool, carefully pry up ZIF connectors as shown. This will allow the black ribbons to detach from the keyboard.
    • Slide the two parts away from each other so that the black ribbons slide through the slots and you will now have housing into two parts.
Melinda Phan
crwdns2935283:004/17/11crwdne2935283:0
438 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-64, Walters Spring 2011 crwdns2935289:0Cal Poly, Team 9-64, Walters Spring 2011crwdne2935289:0
CPSU-WALTERS-S11S9G64
crwdns2935297:018crwdne2935297:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 3,969
