If your HTC Touch isn't powering on, freezing, or showing display issues, the motherboard may need a replacement. This guide will walk you through each step of removing and replacing the motherboard safely. With a few simple tools and careful handling, you can restore your device to its former glory without a costly repair shop visit.
Be sure to power off your device, remove the battery, and ground yourself before beginning to prevent static damage!
Remove the back panel by sliding it up.
Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
Use the plastic opening tool to remove the front panel from the phone.
Unplug the front button cable from the inside of the phone.
Unscrew the 2 torx-head screws at the base of the LCD screen using the T5 Torx Screwdriver.
Separate the motherboard from the black plastic casing.
Unplug the black and red wire from the motherboard.
Unplug the black and red wire from the black plastic casing.
Lift the black lever next to the orange ribbon cable to remove the LCD screen.
Remove the camera lens from the motherboard.
