HTC Touch Camera Lens Replacement
  1. HTC Touch Camera Lens Replacement, Camera Lens: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the back panel upward using the grip at the bottom until it releases.
    • Lift and remove the panel.
  2. HTC Touch Camera Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to grip the battery and remove it from its compartment.
    • Set it aside in a safe place.
  3. HTC Touch Camera Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
    • Keep the screws in a safe place so you don’t lose them.
  4. HTC Touch Camera Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Touch Camera Lens Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to remove the front panel from the phone.
    • Unplug the front button cable from the inside of the phone.
  5. HTC Touch Camera Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the torx-head screws at the base of the LCD screen using the T5 Torx Screwdriver.
  6. HTC Touch Camera Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Touch Camera Lens Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Seperate the motherboard from the black plastic casing.
    • Unplug the black and red wire from the motherboard.
    • Unplug the black and red wire from the black plastic casing.
  7. HTC Touch Camera Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the black lever next to the orange ribbon cable to remove the LCD Screen.
  8. HTC Touch Camera Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the camera lens from the motherboard using the plastic opening tool.
    • Align and insert the new camera lens into the opening. Press it into place until it is secure.
You've successfully replaced your HTC Touch's camera lens! Test your camera to ensure the new lens works properly and your images are clear. To reassemble your device, follow these instructions in reverse order.
Sehyun
crwdns2935283:003/31/11crwdne2935283:0
69 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-12, Regan Spring 2011 crwdns2935289:0Cal Poly, Team 15-12, Regan Spring 2011crwdne2935289:0
CPSU-REGAN-S11S15G12
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 2,728
