HTC Thunderbolt Speaker Replacement
  1. HTC Thunderbolt Speaker Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. HTC Thunderbolt Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the rear panel.
  3. HTC Thunderbolt Speaker Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Thunderbolt Speaker Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  4. HTC Thunderbolt Speaker Replacement, Rear Frame: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six Phillips screws from the perimeter of the rear frame.
    • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
  5. HTC Thunderbolt Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Thunderbolt Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
    • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Remove the plastic cover.
    • The plastic cover will have adhesive on it making it difficult to remove.
  6. HTC Thunderbolt Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillips screws where the plastic cover was.
  7. HTC Thunderbolt Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Thunderbolt Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
    • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Do the same for the opposite side of the phone.
  8. HTC Thunderbolt Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Thunderbolt Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Thunderbolt Speaker Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully separate the screen and phone from the rear frame, starting from the bottom.
    • Gently pull down on the phone and screen to fully separate it from the rear frame.
  9. HTC Thunderbolt Speaker Replacement, Rear Inner Frame: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillips screws securing rear inner frame to device.
  10. HTC Thunderbolt Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the plastic opening tool between the rear inner frame and the motherboard and slowly work your way around the device.
  11. HTC Thunderbolt Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Thunderbolt Speaker Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rear inner frame from the rest of the device.
  12. HTC Thunderbolt Speaker Replacement, Speaker: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip over rear inner frame.
  13. HTC Thunderbolt Speaker Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Thunderbolt Speaker Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry out speaker with plastic opening tools.
    • You have now removed the speaker.
Brandon Younger
crwdns2935283:001/17/13crwdne2935283:0
212 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-45, Regan Winter 2013 crwdns2935289:0Cal Poly, Team 19-45, Regan Winter 2013crwdne2935289:0
CPSU-REGAN-W13S19G45
crwdns2942667:0crwdne2942667:0 713
