HTC Thunderbolt LCD/Screen Replacement
    1. HTC Thunderbolt LCD/Screen Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
      • Gently pry up on the rear panel around the edges until it is loose.
    2. HTC Thunderbolt LCD/Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift and remove the rear panel.
    1. HTC Thunderbolt LCD/Screen Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Thunderbolt LCD/Screen Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
      • Remove the battery from the inner frame.
    1. HTC Thunderbolt LCD/Screen Replacement, MicroSD Card: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Thunderbolt LCD/Screen Replacement, MicroSD Card: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
    2. HTC Thunderbolt LCD/Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
    1. HTC Thunderbolt LCD/Screen Replacement, Rear Frame: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the six Phillips screws from the perimeter of the rear frame.
      • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
    2. HTC Thunderbolt LCD/Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Thunderbolt LCD/Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
      • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
      • Remove the plastic cover.
      • The plastic cover will have adhesive on it making it difficult to remove.
    3. HTC Thunderbolt LCD/Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two Phillips screws where the plastic cover was.
    4. HTC Thunderbolt LCD/Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Thunderbolt LCD/Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
      • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
      • Do the same for the opposite side of the phone.
    5. HTC Thunderbolt LCD/Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Thunderbolt LCD/Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Thunderbolt LCD/Screen Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully separate the screen and phone from the rear frame, starting from the bottom.
      • Gently pull down on the phone and screen to fully separate it from the rear frame.
    1. HTC Thunderbolt LCD/Screen Replacement, Rear Inner Frame: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two Phillips screws securing rear inner frame to device.
    2. HTC Thunderbolt LCD/Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert the plastic opening tool between the rear inner frame and the motherboard and slowly work your way around the device.
    3. HTC Thunderbolt LCD/Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Thunderbolt LCD/Screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the rear inner frame from the rest of the device.
    1. HTC Thunderbolt LCD/Screen Replacement, LCD/Screen: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Thunderbolt LCD/Screen Replacement, LCD/Screen: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the tip of an plastic opening tool flip up the tab holding the capacitive button ribbon cable.
      • Be careful opening these tabs as they are very easy to break.
      • Use a pair of tweezers to pull the capacitive button cable out of its socket.
    2. HTC Thunderbolt LCD/Screen Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Thunderbolt LCD/Screen Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lifting from the side where the ribbon was disconnected, flip over the motherboard.
      • Remove the black tape covering the tabs connecting the motherboard and LCD.
    3. HTC Thunderbolt LCD/Screen Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the plastic opening tool pop up the two tabs connecting the LCD and motherboard.
    4. HTC Thunderbolt LCD/Screen Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Thunderbolt LCD/Screen Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once the tabs have been popped up, slowly pull the two pieces away from each other.
      • If there is resistance pulling apart the phone then a ribbon or tab has not been disconnected properly/completely.
crwdns2935229:011crwdne2935229:0
Brandon Younger
crwdns2935283:001/17/13crwdne2935283:0
212 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-45, Regan Winter 2013 crwdns2935289:0Cal Poly, Team 19-45, Regan Winter 2013crwdne2935289:0
CPSU-REGAN-W13S19G45
crwdns2935297:0144crwdne2935297:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 105
crwdns2942667:0crwdne2942667:0 7,389
