HTC One X Plus Top Speaker Replacement
  1. HTC One X Plus Top Speaker Replacement, Top Speaker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold down the power button to turn off your device.
    • Insert a pin, paper clip, or another similar object into the hole next to the micro sim card holder to remove it.
    • The SIM card slot is located on the top edge of the device.
  2. HTC One X Plus Top Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One X Plus Top Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One X Plus Top Speaker Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using plastic opening tools, pry open the bottom of the device.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached use the suction cup tool to remove the screen completely from the black casing.
  3. HTC One X Plus Top Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One X Plus Top Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One X Plus Top Speaker Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five 2.4mm screws located around the camera using a Philips head screwdriver to remove the plastic cover.
    • Once you have disassembled your device the warranty will no longer be valid.
  4. HTC One X Plus Top Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One X Plus Top Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One X Plus Top Speaker Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the J000 Philips screwdriver to remove the screws and remove the PCB board and antenna.
    • These are two 3.4mm Philips head screws found in the lower right corner of the phone.
  5. HTC One X Plus Top Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC One X Plus Top Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the power button flex cable using tweezers to disconnect from the phone.
    • Use the tweezers to then disconnect the touch screen flex cable.
  6. HTC One X Plus Top Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One X Plus Top Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One X Plus Top Speaker Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery connections to the logic board.
    • This is the six pin connector seen in the red box.
    • Pull the battery away to remove from the back of the screen.
  7. HTC One X Plus Top Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC One X Plus Top Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • CAUTION: carefully remove the top speaker from the phone using tweezers.
Jason Melo
crwdns2935283:008/26/15crwdne2935283:0
483 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-3, Eyestone Fall 2015 crwdns2935289:0USF Tampa, Team 3-3, Eyestone Fall 2015crwdne2935289:0
USFT-EYESTONE-F15S3G3
crwdns2942667:0crwdne2942667:0 538
