HTC One X Plus Motherboard Replacement
  1. HTC One X Plus Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro sim card holder to remove it.
    • The Sim Card Slot is located on the top edge of the device.
  2. HTC One X Plus Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One X Plus Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One X Plus Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
  3. HTC One X Plus Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One X Plus Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One X Plus Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Philips head screw driver, remove the five 2.4mm screws that are pictured. Then remove the plastic cover.
    • Once you have disassembled your device the warranty will no longer be valid.
  4. HTC One X Plus Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One X Plus Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One X Plus Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the J000 Philips screw driver head to remove the screws as pictured.
    • There are two 3.4mm screws to be removed.
    • Remove the PCB board and the antenna.
  5. HTC One X Plus Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC One X Plus Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, disconnect the power button flex cable.
    • Then disconnect the touch screen flex cable.
  6. HTC One X Plus Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One X Plus Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One X Plus Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the battery from the logic board.
    • Look for a white six pin connector.
    • Remove the battery by pulling upwards.
  7. HTC One X Plus Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the remaining two flex cables following the same procedure from Step 5.
    • Once these two flex cables have been disconnected, you may now remove the motherboard.
Jason Melo
crwdns2935283:008/26/15crwdne2935283:0
483 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-3, Eyestone Fall 2015 crwdns2935289:0USF Tampa, Team 3-3, Eyestone Fall 2015crwdne2935289:0
USFT-EYESTONE-F15S3G3
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,315
