HTC One X Battery Replacement
crwdns2936621:0crwdne2936621:0
  1. HTC One X Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One X Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One X Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Switch the phone off.
    • Remove the SIM tray.
    • The back cover is stuck to the phone with adhesive tape.
    • It's helpful to use heat to loosen the adhesive, making removal much easier.
  2. HTC One X Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One X Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One X Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Start opening from the bottom side.
    • For separating the back cover, use only plastic tools.
  3. HTC One X Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC One X Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the display assembly from the body of the phone.
  4. HTC One X Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC One X Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the seven Philips #0 screws at the top of the panel:
    • Two 2.05 mm screws
    • Three 2.44 mm screws
    • Two 3.35 mm screws
    • Once the screws are removed, gently remove the plastic cover using a plastic opening tool to detach the edges from the front panel.
  5. HTC One X Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One X Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One X Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect one by one:
    • the Touchscreen flex cable
    • the Volume buttons & Mic flex cable
    • the Dock connector flex cable
    • Carefully insert a plastic tool under the battery to pry it up from the adhesive. Avoid bending the battery.
    • Be careful, there are flex cables under the battery. At the last picture in this step you can see the cables and the place were is adhesive tape.
    • Now you can separate the Dock flex cable.
  6. HTC One X Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC One X Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • A piece of copper tape covers the battery and an EMI shield on the motherboard.
    • Carefully pry the EMI shield up at the top of the phone and toward the battery.
    • Carefully peel the copper tape off of the battery and save it to transfer to the new battery.
  7. HTC One X Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One X Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One X Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the motherboard slightly to disconnect two flex cables:
    • the LCD Display flex cable
    • the Navigation buttons flex cable
    • Disconnect the Power On button flex cable at the upper side of the phone
    • Now the mainboard and the battery are free.
    • Disconnect the battery and you are ready to install the new one.
  8. HTC One X Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC One X Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
crwdns2935229:013crwdne2935229:0
ZFix
crwdns2935283:012/09/13crwdne2935283:0
194 325 crwdns2915208:0crwdne2915208:0
crwdns2935297:0330crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0326crwdne2931471:0
crwdns2935297:01 685crwdne2935297:0
Perfecto! Me vino genial el tutorial y es perfecto, mejor que otros.
hepugh - crwdns2934203:0crwdne2934203:0
Went very well. I had a dead HTC One X that I replaced 4 years ago. I came across it a few weeks ago and thought to give a new battery a try, to see if I can get the photos off it. It did not charge (no lights) and did not turn on anymore. I ordered a battery from AliExpress and it came in today. Followed this guide, and yes, it turned on again! And charging is also working properly now. So I am happy, now I can get my photos and use the phone as a Android 4.2 testing target for the apps I develop. Wonderful.
Peterdk - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 46,893
