HTC One V Ear Speaker Replacement
  1. HTC One V Ear Speaker Replacement, Disassembling HTC ONE V Bottom Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One V Ear Speaker Replacement, Disassembling HTC ONE V Bottom Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One V Ear Speaker Replacement, Disassembling HTC ONE V Bottom Assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power off your device.
    • Remove the bottom cover by sliding it off.
  2. HTC One V Ear Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the SIM card.
    • Remove the four screws securing the bottom casing.
    • Two 3.0 mm Phillips #0 screws in the top left and right corners.
    • Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
  3. HTC One V Ear Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC One V Ear Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2.0 mm Phillips #0 screws on either side of the phone.
  4. HTC One V Ear Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One V Ear Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One V Ear Speaker Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to pry open the bottom casing.
    • Remove the bottom casing by pulling it towards you.
  5. HTC One V Ear Speaker Replacement, Disassembling HTC One V Back Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One V Ear Speaker Replacement, Disassembling HTC One V Back Case: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One V Ear Speaker Replacement, Disassembling HTC One V Back Case: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to pry open the rear camera panel.
    • Remove both screws that are securing the back case.
    • One 4.0 mm Phillips #0 screw.
    • One 3.0 mm Phillips #0 screw.
  6. HTC One V Ear Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One V Ear Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One V Ear Speaker Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Jimmy to pry up the OEM SIM and SD card reader contact.
    • Pry from right to left to avoid potential damages to the ribbon.
  7. HTC One V Ear Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One V Ear Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One V Ear Speaker Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using both thumbs, gently push on the two bottom rear corners of the motherboard.
    • Gently and slowly pull the screen out from the front of the phone, while feeding the OEM reader contact through the opening.
  8. HTC One V Ear Speaker Replacement, Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the battery with the flat end of the spudger.
  9. HTC One V Ear Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One V Ear Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One V Ear Speaker Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift up the battery away from the edge of its housing.
    • Use the point end of the spudger to push the connection out of its housing.
  10. HTC One V Ear Speaker Replacement, Camera Lens: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One V Ear Speaker Replacement, Camera Lens: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One V Ear Speaker Replacement, Camera Lens: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 3.0 mm Phillips #0 screws, that are securing the camera lens.
  11. HTC One V Ear Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off the camera lens using a plastic opening tool.
  12. HTC One V Ear Speaker Replacement, Vibrator: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC One V Ear Speaker Replacement, Vibrator: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the vibrator out of the housing with a spudger.
    • Using the tweezers, pull up on the connecting wires detaching the vibrator from the motherboard.
  13. HTC One V Ear Speaker Replacement, Motherboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One V Ear Speaker Replacement, Motherboard: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One V Ear Speaker Replacement, Motherboard: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the spudger lift the tabs on the highlighted, red and orange, ribbon connectors. Gently pull out the ribbons from their connectors.
    • Remove the 3.0 mm Phillips #0 screw.
  14. HTC One V Ear Speaker Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One V Ear Speaker Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One V Ear Speaker Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using tweezers, pull back on the tape located on the bottom corners of the motherboard.
  15. HTC One V Ear Speaker Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC One V Ear Speaker Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to push back the latch holding on the motherboard. While the latch is pushed back use the plastic opening tool to pry up the motherboard.
  16. HTC One V Ear Speaker Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place your phone on its side so that you can gently pull up on the motherboard to expose its last connector.
    • Using the flat end of the spudger, pop of the connector.
  17. HTC One V Ear Speaker Replacement, Ear Speaker: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull off the ear speaker using the tweezers.
Michael Lucido
crwdns2935283:001/20/15crwdne2935283:0
852 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-3, Blackwell Winter 2015 crwdns2935289:0USF Tampa, Team 1-3, Blackwell Winter 2015crwdne2935289:0
USFT-BLACKWELL-W15S1G3
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 450
