HTC One Mini Screen Replacement
    1. HTC One Mini Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a plastic opening tool to remove the bottom speaker cover
    2. HTC One Mini Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your T6 Torx screwdriver to remove the single screw that holds the body to the aluminium back
    3. HTC One Mini Screen Replacement, This step requires a little patience: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC One Mini Screen Replacement, This step requires a little patience: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use only plastic opening tools, metal ones will cause damage to the assembly
      • Use a plastic opening tool next to the usb port to gently lift the bottom away from the backing.
      • Use a second tool to work your way around the phone undoing the clips while the first tool lifts the undone areas
    4. HTC One Mini Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your heat gun and infra-red thermometer to heat the screen assembly to 130 degrees C (265 F) to soften the adhesive
      • Use opening tool to gently lift the edges of the screen away from the body working from the top down.
      • Don't try to remove the bottom of the screen as your flex cables are there and still attached to the logic board
    5. HTC One Mini Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Undo the 2 Phillips screws circled in red and detach the battery connector (so we don't short anything out)
      • Undo the 3 screws holding down the bottom of the logic board and charger port circled in green
      • Undo the flex cables and speaker power cable circled in blue and lift the charger port out
      • The flex cable for this board and the one next to it for the screen their locking tabs open from the back
      • Gently using a plastic opening tool lift out the bottom speaker
      • Also the rubber spacer circled in blue
      • Undo the flex cables circled in orange and slowly start pulling the old screen out
    6. HTC One Mini Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove any old adhesive and broken glass from the frame
      • Gently feed through the flex cables taking great care not to break them
      • Don't remove any of this sheilding tape, I have only removed it to show you that there is nothing under there and I have replaced it during reassembly
    7. HTC One Mini Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Fold the screen away from the body keeping in mind not to damage the flex cables.
      • Add your strips of adhesive tape to the frame and put put the screen onto the body (I have highlighted the placement areas in blue)
      • You will have to cut the tape in half for the sides of the screen. Using a razor blade and a metal ruler will give best results.
      • Follow the steps in reverse for reassembly and use a couple of drops of super glue to put the front speaker cover back on
crwdns2935229:010crwdne2935229:0
Robbie
crwdns2935283:007/11/14crwdne2935283:0
655 crwdns2915208:0crwdne2915208:0
I just need to change the touch digitizer, how do I detach it from the LCD?
hudeor - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can i find a replacement screen
pietro.faraggiana - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 106
crwdns2942667:0crwdne2942667:0 37,653
