HTC One Max Battery Replacement
  1. HTC One Max Battery Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
  2. HTC One Max Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC One Max Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
  3. HTC One Max Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
    The orange circle in line with the 4 other red circles down the RH side (as shown) in the photo should be red also, as this shows a screw, not the cable (which is by the volume buttons).
    Huey Smith - crwdns2934203:0crwdne2934203:0
    Hey Huey,
    Nice catch! This has now been fixed.
    Geoff Wacker -
  4. HTC One Max Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC One Max Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the small plastic opening tool to pry between the screen and the rear case.
  5. HTC One Max Battery Replacement, Fingerprint Sensor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC One Max Battery Replacement, Fingerprint Sensor: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
    • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
  6. HTC One Max Battery Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC One Max Battery Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
    • Use a plastic tool to remove the ribbon cable.
  7. HTC One Max Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC One Max Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to disconnect the two antenna wires at the top of the phone.
    • Use the plastic opening tool to disconnect a third antenna wire at the bottom of the phone.
    Where can i find a replacemt ir blaster?
    yuuki1942 - crwdns2934203:0crwdne2934203:0
  8. HTC One Max Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven 3 mm Phillips #000 screws from the motherboard.
  9. HTC One Max Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One Max Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One Max Battery Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic tool to pry up and disconnect the large ribbon cables on each side of the motherboard.
    • Use caution prying the ribbon cable on the right side because other ribbon cables run under it.
  10. HTC One Max Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One Max Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One Max Battery Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
    • Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
    What does the orange circle refer to, as the text is a duplicate of the red circle description (and the highlighted item isn't connected with the three gate connectors)?
    I think the orange circle refers to a 4th gate connector which needs to be disconnected.
  11. HTC One Max Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC One Max Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic tool to lift and remove the motherboard.
    • Use a heat gun to loosen adhesive at bottom if needed.
  12. HTC One Max Battery Replacement, IR Blaster: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 3 mm Phillips #000 screws from the secondary board at the top.
  13. HTC One Max Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pick up and set aside vibrator, do not disconnect.
  14. HTC One Max Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out ribbon cable.
    • Peel back infrared sensor.
    the orange circle pointed at ribbon cable while the red pointed at infrared sensor
    mohamedeldeeb69 - crwdns2934203:0crwdne2934203:0
  15. HTC One Max Battery Replacement, Camera Board: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC One Max Battery Replacement, Camera Board: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the secondary board with the camera attached.
    • Be advised of the adhesive on the back.
  16. HTC One Max Battery Replacement, Remove Bottom Screws: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two screws from the bottom.
    • Set aside metal retaining plate.
  17. HTC One Max Battery Replacement, Speaker Assembly: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC One Max Battery Replacement, Speaker Assembly: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry back the speaker and microphone assembly from the bottom.
    • Be careful to not poke the speaker.
  18. HTC One Max Battery Replacement, Remove Battery: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC One Max Battery Replacement, Remove Battery: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC One Max Battery Replacement, Remove Battery: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the battery away from the back of the screen with a plastic tool.
    • We recommend using a heat gun to loosen the adhesive holding the battery in place.
crwdns2935229:015crwdne2935229:0
Andrey Sklyar
crwdns2935283:009/23/14crwdne2935283:0
452 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 11-3, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 11-3, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S11G3
Microphone in the article, battery in the title.
AaronAndrusko - crwdns2934203:0crwdne2934203:0
How to change LCD screen for this model?
Jembalang Tanah - crwdns2934203:0crwdne2934203:0
What the &&^& man i prefer to buy another phone %#*@ it
Russel - crwdns2934203:0crwdne2934203:0
What the &&^& man i prefer to buy a new phone
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 15,593
