Use this guide to replace the back case on your HTC One Max.
Lift back cover while pressing highlighted release switch towards the center of the phone.
Remove the four white stickers in each corner that cover the Tri-Wing screws.
Remove the white sticker near the buttons that control the volume.
Remove the white sticker near the SIM card.
Remove the big white sticker with the bar-code in the center of the phone.
Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
Disconnect the cable near the volume buttons.
Use the small plastic opening tool to pry between the screen and the rear case.
crwdns2947412:05crwdne2947412:0
any idea where i can purchase that back case?
omair - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The "Tools" section of the guide lists a Y0 screwdriver as required but in the steps it says Y1. Now I have a Y0 screwdriver i can't do anything with and i have to order a Y1. Hopefully that is accurate.
khaydin - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Soooo... unless your HTC One MAX is completely different from the Sprint one i'm trying to replace the back on, both the Y0 and Y1 screw drivers are WRONG for this phone. They are both a bit too big to work on the screws. Now I've bought TWO screw drivers from you guys that were incorrect. Guess i'm gonna need to go out and buy a tri-wing screw driver set.
You need a #Y00 which is smaller then a #Y0 and #Y1 .
Leonturner21 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The site tells you to use a #Y00 and it does work for any HTC One Max
