HTC Hero Motherboard Replacement
  1. HTC Hero Motherboard Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
  2. HTC Hero Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
  3. HTC Hero Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
  4. HTC Hero Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Hero Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
  5. HTC Hero Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Hero Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Release the two ribbon cables using a plastic opening tool.
    • Gently pry up the pop connectors used to attach the ribbon cables to the motherboard.
  6. HTC Hero Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Hero Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws located at the bottom left and right of the motherboard using a small Phillips screwdriver.
  7. HTC Hero Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Hero Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the motherboard out of the front enclosure once the screws are removed.
Rosalind Villalvazo
crwdns2935283:001/23/12crwdne2935283:0
100 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-26, Amido Winter 2012 crwdns2935289:0Cal Poly, Team 3-26, Amido Winter 2012crwdne2935289:0
CPSU-AMIDO-W12S3G26
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,671
