HTC HD2 Phone Speaker Replacement
  1. HTC HD2 Phone Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the rear cover from the back of the phone.
    • Place a finger beneath the small lip on the left side of the battery.
  2. HTC HD2 Phone Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC HD2 Phone Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the phone down on it's screen.
    • Lift up on the lip and pull the battery from the phone.
  3. HTC HD2 Phone Speaker Replacement, Midframe: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC HD2 Phone Speaker Replacement, Midframe: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four black 3.5mm T5 screws from the back of the phone.
  4. HTC HD2 Phone Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC HD2 Phone Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger between the midframe and the display.
    • Slide the spudger along the seam between the frame and the display.
    • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
    • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
    • As it releases, pull the midframe away from the phone.
    • The volume control tab may fall off during removal. It can be easily reattached.
  5. HTC HD2 Phone Speaker Replacement, Phone Speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the chassis removed, set down the phone and locate the speaker on the inside of the housing.
    • The speaker should be easily popped out of place with a small amount of force
  6. HTC HD2 Phone Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Congratulations! The speaker is now removed and can be replaced or repaired.
Nathan Puchalski
crwdns2935283:004/26/11crwdne2935283:0
813 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-55, Amido Spring 2011 crwdns2935289:0Cal Poly, Team 24-55, Amido Spring 2011crwdne2935289:0
CPSU-AMIDO-S11S24G55
crwdns2942667:0crwdne2942667:0 7,023
