HTC Fortress Camera Replacement
  1. HTC Fortress Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Fortress Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back cover of the device by sliding it upward.
    • You may need to remove the phone stylus first.
  2. HTC Fortress Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Fortress Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery by pulling it away from the back of the phone.
  3. HTC Fortress Camera Replacement, Camera: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Fortress Camera Replacement, Camera: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the top 2 screws on the back of the phone with the T4 Screwdriver.
  4. HTC Fortress Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Fortress Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Fortress Camera Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the camera panel by hand (black cover above the battery slot).
    • Be careful; there is a cable attached underneath the case. It does detach, just pull on it carefully.
    • During reassembly, put the cable back in by holding the black piece slightly above its slot and using the spudger to gently press the end of the cable back into its fitting. Then, insert the black piece so it is flush with the black panel again.
  5. HTC Fortress Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Fortress Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Fortress Camera Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Work the metal camera casing off by slowly prying up the sides using the spudger.
  6. HTC Fortress Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Fortress Camera Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tweezers to pull the camera straight out of the phone.
Lucas David
crwdns2935283:004/19/13crwdne2935283:0
540 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-13, Maness Spring 2013 crwdns2935289:0Cal Poly, Team 4-13, Maness Spring 2013crwdne2935289:0
CPSU-MANESS-S13S4G13
crwdns2935297:022crwdne2935297:0
crwdns2942667:0crwdne2942667:0 489
