HTC Excalibur Screen Replacement
  1. HTC Excalibur Screen Replacement, Logic Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start off with a clean open space to work in and then power off your phone.
    • Remove the SIM card and microSD, if it was inserted.
  2. HTC Excalibur Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To take off the back cover, you can use a pry tool or your fingernail to take it off.
    • Gripping the battery by the bottom, lift and remove it from the phone.
  3. HTC Excalibur Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Excalibur Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Excalibur Screen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the rubber stoppers on top, there should be six exposed screws. Remove these using the T6 screwdriver.
    • Next, use the spudger to loosen the case underneath the shiny metal edge. Go all the way around the phone until completely loosened.
    • After loosening the case, remove it.
    • When taking the cover off, make sure not to snap any of the clips that are attached to the phone.
    • There is a wire that connects both the top and bottom of the case. If you are not careful when removing the case, you might snap the wire.
  4. HTC Excalibur Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Excalibur Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect all the ribbon cables that are connected to the logic board and do it either with the plastic pry tool or tweezers.
    • If there are any extra screws, ensure they are all out.
  5. HTC Excalibur Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Excalibur Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Excalibur Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the left side of the phone, there are three copper colored clips.
    • Unclip the bottom clip, thread the middle one through the logic board, and pull the top one out gently.
    • You can then lift the logic board out of the phone.
    • Be gentle when taking the logic board out and be mindful of any remaining connectors or adhesive.
    • When installing the logic board, make sure it is aligned properly in the phone.
    • After, reconnect all the ribbon cables back to the logic board and insert the screws again.
    • Including reinserting the battery, SIM card, and microSD card.
    • Finally, turn off the phone back on and check if it functions.
    • Double check if calls, Wi-Fi, touchscreen, and the buttons work after the replacement.
  6. HTC Excalibur Screen Replacement, Screen: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal frame. Slip out the copper clips still attached to the bottom frame from the frame carefully.
  7. HTC Excalibur Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the screen by the bottom edge, and lift it out at an angle.
    • Replace the screen, and reassemble the phone.
Ian Mitchell
crwdns2935283:004/19/11crwdne2935283:0
142 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 25-27, Garner Spring 2011 crwdns2935289:0Cal Poly, Team 25-27, Garner Spring 2011crwdne2935289:0
CPSU-GARNER-S11S25G27
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 1,865
