HTC Excalibur Logic Board Replacement
  1. HTC Excalibur Logic Board Replacement, Logic Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start off with a clean open space to work in and then power off your phone.
    • Remove the SIM card and microSD, if it was inserted.
  2. HTC Excalibur Logic Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To take off the back cover, you can use a pry tool or your fingernail to take it off.
    • Gripping the battery by the bottom, lift and remove it from the phone.
  3. HTC Excalibur Logic Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Excalibur Logic Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Excalibur Logic Board Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the rubber stoppers on top, there should be six exposed screws. Remove these using the T6 screwdriver.
    • Next, use the spudger to loosen the case underneath the shiny metal edge. Go all the way around the phone until completely loosened.
    • After loosening the case, remove it.
    • When taking the cover off, make sure not to snap any of the clips that are attached to the phone.
    • There is a wire that connects both the top and bottom of the case. If you are not careful when removing the case, you might snap the wire.
  4. HTC Excalibur Logic Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Excalibur Logic Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect all the ribbon cables that are connected to the logic board and do it either with the plastic pry tool or tweezers.
    • If there are any extra screws, ensure they are all out.
  5. HTC Excalibur Logic Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Excalibur Logic Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Excalibur Logic Board Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the left side of the phone, there are three copper colored clips.
    • Unclip the bottom clip, thread the middle one through the logic board, and pull the top one out gently.
    • You can then lift the logic board out of the phone.
    • Be gentle when taking the logic board out and be mindful of any remaining connectors or adhesive.
    • When installing the logic board, make sure it is aligned properly in the phone.
    • After, reconnect all the ribbon cables back to the logic board and insert the screws again.
    • Including reinserting the battery, SIM card, and microSD card.
    • Finally, turn off the phone back on and check if it functions.
    • Double check if calls, Wi-Fi, touchscreen, and the buttons work after the replacement.
Ian Mitchell
crwdns2935283:004/19/11crwdne2935283:0
142 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 25-27, Garner Spring 2011 crwdns2935289:0Cal Poly, Team 25-27, Garner Spring 2011crwdne2935289:0
CPSU-GARNER-S11S25G27
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 2,263
