In addition to the possibility that the battery may be the reason why your phone is not charging, the charging port may also need to be replaced or tightened if loose. Ensure that the delicate parts of the phone revealed in the replacement procedure.
Use the plastic opening tool to pry off back cover by inserting opening tool in the space indicated and pushing down on the handle of the tool.
Remove the battery after taking off the cover.
Remove eight 4mm and one 5mm Torx screws.
Use a prying tool to pry off the midframe.
Remove the 4mm Torx screw holding the charging port to the phone.
Remove the silver bracket holding the charging port in place.
Use a prying tool to remove the charging port as shown.
