            Find a seam in the back of the device.
            Insert the plastic spudger into the seam and pry off the back panel.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Remove the 4.0 mm screw above the battery with a T5 Torx screwdriver.
            Remove the metal bracket with the tweezers.
            Disconnect the battery cable from the motherboard with the tweezers.
            Lift the battery with a plastic spudger and remove it from the device.
            Use a T5 Torx screwdriver to remove the three 4.0 mm screws.
            Use the spudger to lift the black plastic covering.
            Use the spudger to lift the green board. The back camera is attached on the side as shown.
            Use the tweezers to disconnect and remove the camera.
            Remove the three 4.0 mm T5 Torx screws connected to the motherboard.
            Disconnect the ribbon cable from the motherboard by flipping up the locking tab with a spudger and pulling out the cable with your fingers.
            Lift the motherboard out of the frame, using a spudger to help pick up one of the edges.
            Use a T5 Torx screwdriver to remove the two 4.0 mm screws in the bottom corners of the device.
            Use a T5 Torx screwdriver to remove one screw connected to the daughterboard.
            Remove the interconnect ribbon cable by flipping up the black tab of the ZIF connector and pulling out the cable with your fingers.
            Remove the daughterboard.
            Use a pair of tweezers to unhook the locks on both sides of the speaker.
            Grab the speaker with the tweezers and lift vertically to remove.
