HTC Desire 816 Volume Buttons Replacement
  1. HTC Desire 816 Volume Buttons Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry open the back panel by inserting the plastic opening tool on the left of the camera. We find this spot the easiest to get the tool under the panel.
  2. HTC Desire 816 Volume Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you get an open spot, with a second plastic opening tool, slide down to the bottom of the phone to free the rest of side.
  3. HTC Desire 816 Volume Buttons Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There is adhesive between the battery and the back panel. Take a nylon spudger to cut through the adhesive.
    • Be sure to use the correct tool for the job. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  4. HTC Desire 816 Volume Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all way around the bottom, the panel should be broken free of the adhesive, and the rest of the panel should pop right off.
  5. HTC Desire 816 Volume Buttons Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a nylon spudger at the bottom of the battery and lift up to remove the battery.
  6. HTC Desire 816 Volume Buttons Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There is adhesive on the other side of the battery as well, take the nylon spudger used to get off the panel and cut through.
  7. HTC Desire 816 Volume Buttons Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift battery backside first to disconnect the white connector.
  8. HTC Desire 816 Volume Buttons Replacement, Volume Buttons: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the T5 screw driver, unscrew the four screws that are holding down the black plastic casing.
  9. HTC Desire 816 Volume Buttons Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove black plastic casing from the device with a plastic opening tool.
  10. HTC Desire 816 Volume Buttons Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the PH000 screw driver, unscrew the remaining screw that is holding down the motherboard. It is located on the left side of the motherboard.
  11. HTC Desire 816 Volume Buttons Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a pair of tweezers disconnect the battery wire from board.
  12. HTC Desire 816 Volume Buttons Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a pair of tweezers, located the rubber power button piece and pull towards yourself in order to set it free.
  13. HTC Desire 816 Volume Buttons Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a metal spudger, push the power button out gently.
  14. HTC Desire 816 Volume Buttons Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the a pair of tweezers, locate the rubber button piece and gently lift up in order to set it free.
  15. HTC Desire 816 Volume Buttons Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat the last step but this time it will the rubber piece will be at the other end of the volume buttons.
  16. HTC Desire 816 Volume Buttons Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a metal spudger, gently push the volume button out.
Saleena Douangphachanh
crwdns2935283:003/05/16crwdne2935283:0
618 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-3, Landers Spring 2016 crwdns2935289:0UMass Dartmouth, Team 5-3, Landers Spring 2016crwdne2935289:0
UMASSD-LANDERS-S16S5G3
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 3,047
