HTC Desire 700 Dual Sim Front Facing Camera Replacement
  1. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to pry the back cover off.
  2. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Removing Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use spudger tool to pry under the battery to lift it up and out.
  3. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Remove 8 Torx Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Prying Off Rear Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
  5. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3mm PH00 screw located at the bottom center of the motherboard using a P#00 Phillip's head screwdriver.
  6. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Disconnect Vibrator Wire: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the tweezers gently disconnect the wire from the vibrator located on the motherboard.
  7. HTC Desire 700 Dual Sim Front Facing Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove volume control button ribbon with tweezers.
  8. HTC Desire 700 Dual Sim Front Facing Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the ribbon attached to the top of the motherboard.
  9. HTC Desire 700 Dual Sim Front Facing Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unsnap the wire from the printed circuit board (PCB) using the tweezers.
  10. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Removing Camera: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the camera using the plastic opening tool as shown.
Steven Pate
crwdns2935283:009/23/14crwdne2935283:0
196 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-3, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 9-3, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S9G3
crwdns2942667:0crwdne2942667:0 865
