Has your HTC Desire 610 stopped vibrating? Follow these steps to replace the faulty vibration motor. You will learn how to take off the back, unscrew the circuit cover, unplug the vibration harness, and put in a new motor.
Using a plastic opening tool, take off the back cover of the phone.
Remove the four black 4mm torx screws using the Torx T5 bit.
Remove the four silver 5mm torx head screws using the Torx T5 screwdriver.
Remove the two 2.5mm phillips head screws using the Phillips 000 screwdriver.
Remove the black plastic circuit cover using a plastic opening tool.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Pull the wire harness from the circuit board that is connected to the vibration motor using a pair of precision tweezers.
Pry the vibration motor from it's housing using precision tweezers.
