Is your HTC Desire 610 not holding a charge? Instead of taking it to your phone provider, follow these steps and you can replace that old battery in no time! It's as simple as: take off the back, unscrew the circuit cover, pry out the old battery, and put in a new one. Ta-dah!
Using plastic opening or prying tool, take off the back cover of the phone.
The SD slot opens an area where the edge of the back is exposed and can be pried open easily.
Using Phillips 000 Screwdriver, remove the two 2.5mm phillips head screws.
Using Torx T5 screwdriver, remove the four silver 5mm torx head screws.
Using Torx T5 bit size, remove the four black 4mm torx screws
Using plastic opening or prying tool, remove the black plastic circuit cover.
It's a bit fiddly around the camera lens end, but gently lift the frame up and it unhooks.
Using small plastic opening tool, disconnect the wire connection. Do this by carefully inserting tool under wires and pulling straight up.
The iFixIt prying tool was too clunky. The iFixIt needle nose tweezers were a much better option.
Use the plastic opening tool - you can use a larger one, or keep using the small one - to pry out the battery.
This took a bit of gentle prying with the plastic opening tool and the plectrum thing. I was super careful as the battery had ballooned and could have been unstable. I didn't want to damage it and have a lithium battery fire on my dining table!
Well done! I allways repair iphones, but my own phone is this HTC Desire 610 and I hadn't T5 torx for disassemble it. ;)
Hi thanks for the useful video, however after changing it the new battery didnt work. I tried charging and turning on. I replaced with the old one which still charged and was usable but this then also didnt work. Ive checked connections etc. Any other suggestions? Many thanks
@simon and anybody, Another suggestion is to control the connect cable screen which passes under the battery and plugs upside down under the motherboard because it is frequent that it disconnects when we remove the old battery and the smartphone no longer restarts Next.
Thank you very much to the author of this tutorial which I serve me for a friend in January 2024
