All phones have an antenna in them, this is what allows us to make phone calls and get signals from cell-phone towers. These fixes are generally easy, because the antennas are just small, paper-looking strips that are glued somewhere in or on the chassis of the phone.
Remove the four 1.2mm screws in the corners to release the front of the phone from the back, then pry it off with the plastic opening tool.
Remove the back of the phone from the front.
Use a spudger to gently lift one side of the antenna strip up, then pull it off. This needs to be done in all four corners.
