HTC Desire 510 Touch screen Glass and/or LCD Display
crwdns2936621:0crwdne2936621:0
  1. HTC Desire 510 Touch screen Glass and/or LCD Display, BATTERY REMOVAL: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Desire 510 Touch screen Glass and/or LCD Display, BATTERY REMOVAL: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Desire 510 Touch screen Glass and/or LCD Display, BATTERY REMOVAL: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Switch off the phone, remove the battery and any installed SIM and memory cards.
    • Remove 7x Torx T5 screws.
  2. HTC Desire 510 Touch screen Glass and/or LCD Display, REAR BEZEL REMOVAL: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Desire 510 Touch screen Glass and/or LCD Display, REAR BEZEL REMOVAL: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Desire 510 Touch screen Glass and/or LCD Display, REAR BEZEL REMOVAL: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic tool to remove the rear bezel.
    • The loudspeaker is on the inner side of the rear bezel.
  3. HTC Desire 510 Touch screen Glass and/or LCD Display, FLEX CABLES DISCONNECTING: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Desire 510 Touch screen Glass and/or LCD Display, FLEX CABLES DISCONNECTING: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Desire 510 Touch screen Glass and/or LCD Display, FLEX CABLES DISCONNECTING: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the touch screen flex cable.
    • Disconnect the light sensor flex cable.
    • Unstuck the vibra-motor from the middle frame.
    • Remove the coaxial antenna cable from the middle frame.
    • The LCD display flex cable is connected to the bottom side of the board.
  4. HTC Desire 510 Touch screen Glass and/or LCD Display, LOGIC BOARD REMOVAL: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Desire 510 Touch screen Glass and/or LCD Display, LOGIC BOARD REMOVAL: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Desire 510 Touch screen Glass and/or LCD Display, LOGIC BOARD REMOVAL: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At the upper left side, the board is held by a plastic locking clip. Use a plastic tool and start the separating from here.
    • Gently disconnect the LCD display flex cable.
    • Now remove the logic board.
  5. HTC Desire 510 Touch screen Glass and/or LCD Display, PREPARATION THE GLASS: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Desire 510 Touch screen Glass and/or LCD Display, PREPARATION THE GLASS: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Desire 510 Touch screen Glass and/or LCD Display, PREPARATION THE GLASS: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put a scotch tape to prevent the glass from scattering.
    • Use a hot gun or hair dryer and warm the glass. This will make the adhesive soften and the separation easier.
  6. HTC Desire 510 Touch screen Glass and/or LCD Display, SEPARATION THE GLASS: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Desire 510 Touch screen Glass and/or LCD Display, SEPARATION THE GLASS: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Desire 510 Touch screen Glass and/or LCD Display, SEPARATION THE GLASS: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a cutter and slightly lift the glass in one of the corners. When you make enough room, put a plastic tool.
    • Continue the separating with plastic tools to prevent the middle frame from scratches.
  7. HTC Desire 510 Touch screen Glass and/or LCD Display, SEPARATION THE GLASS (2): crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Desire 510 Touch screen Glass and/or LCD Display, SEPARATION THE GLASS (2): crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Desire 510 Touch screen Glass and/or LCD Display, SEPARATION THE GLASS (2): crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The digitizer flex cable goes under the LCD display.
    • Slightly lift the display and unstuck the digitizer ribbon cable from the from the rear side of the display.
  8. HTC Desire 510 Touch screen Glass and/or LCD Display, LCD DISPLAY: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Desire 510 Touch screen Glass and/or LCD Display, LCD DISPLAY: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Desire 510 Touch screen Glass and/or LCD Display, LCD DISPLAY: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you have a broken LCD display, use a plastic tool and remove it from the middle frame.
    • It's not glued to the frame.
  9. HTC Desire 510 Touch screen Glass and/or LCD Display, INSTALLING THE NEW SPARE PART: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Desire 510 Touch screen Glass and/or LCD Display, INSTALLING THE NEW SPARE PART: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Desire 510 Touch screen Glass and/or LCD Display, INSTALLING THE NEW SPARE PART: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Install a new adhesive tape on the digitizer glass.
    • First put the touch screen flex cable in the right hole and then install the LCD Display.
  10. HTC Desire 510 Touch screen Glass and/or LCD Display, REASSEMBLING: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Desire 510 Touch screen Glass and/or LCD Display, REASSEMBLING: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now is time to reassemble the phone.
    • That's all.
    • Did you do it successfully?
crwdns2935229:010crwdne2935229:0
ZFix
crwdns2935283:012/09/13crwdne2935283:0
195,384 crwdns2915208:0crwdne2915208:0
crwdns2935297:0330crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0328crwdne2931471:0
crwdns2935297:01,437crwdne2935297:0
thanks for this mate, super helpful
kommer - crwdns2934203:0crwdne2934203:0
I did exactly this and when I turn on my phone, the digitizer recognizes touches for a few milliseconds (buggy touches) when I touch it then it stops recognizing touches. What did I do wrong?
Generic Email - crwdns2934203:0crwdne2934203:0
hello i want to buy HTC desire 510 Screen because my htc mobile Touch is not working. i want to buy. plz tell me to am i buy .
imran Ali Gaming - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 15,640
