HTC Amaze Back Panel Disassembly
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. HTC Amaze Back Panel Disassembly, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Amaze Back Panel Disassembly, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently press the Release Button located at the bottom of the phone in order to remove the back panel of the device.
  2. HTC Amaze Back Panel Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you locate the battery, look for a notch below it.
    • Gently insert your fingernails into the notch.
    • Lift the battery out of its recess.
  3. HTC Amaze Back Panel Disassembly, HTC Amaze Back Panel Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Amaze Back Panel Disassembly, HTC Amaze Back Panel Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Amaze Back Panel Disassembly, HTC Amaze Back Panel Disassembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Torx T5 screwdriver to remove the 7 Torx Screws (3mm) attached to the back housing of the device.
    • One of the Screws may have a tape attached to it that says void. Removing this screw will void the devices warranty.
  4. HTC Amaze Back Panel Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HTC Amaze Back Panel Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HTC Amaze Back Panel Disassembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Proceed to remove the back housing by using the spudger to gently unclip each clip holding the back housing in place and then lift the outer edges of the back housing
    • If you're having trouble opening the back try using the spudger to gently pry all around the panel before you attempt to remove it.
  5. HTC Amaze Back Panel Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HTC Amaze Back Panel Disassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now simply remove the back panel by gently pulling. This will make it easier to access the devices internal components.
Jonah DIngle
crwdns2935283:009/22/16crwdne2935283:0
286 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 16-3, Eyestone Fall 2016 crwdns2935289:0USF Tampa, Team 16-3, Eyestone Fall 2016crwdne2935289:0
USFT-EYESTONE-F16S16G3
crwdns2942667:0crwdne2942667:0 43
