Remove the 2 Screw covers from the lower sides of the Bezel
Use a pick along the top and sides of the bezel to start removing the bezel. Use your fingers to gently pry from the bottom of the bezel while pulling up. Bezel is very fragile.
Remove the 2 screws from the top of the frame, One on each side.
Remove the 4 screws holding the LCD to the frame. 2 on each side.
Lay the LCD down on the keyboard and remove the webcam cable (if you have one) and remove the video cable.
crwdns2917034:0crwdne2917034:0
Video guide How to disassemble HP Compaq G71 https://youtu.be/TsoP3EdbHz8
