Is your monitor not powering on? Is the power button making a weird clicking noise? You might need to replace the power button.
Turn monitor so that the screen is facing you.
Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
Remove the power button from the top of the plastic frame.
Remove the power cable by carefully sliding it out of it's plug.
