Are you unable to adjust the sound on you HP w2216h monitor? You may need to replace your control buttons. These buttons are responsible for sound adjustment, calibration, input selection, and more.
Remove the four 12 mm Phillips #000 screws on the back panel.
Remove the two 12 mm Phillips #000 screws above stand mounting bracket.
Using a Phillips #1 with the 150 mm flexible extension remove 1 Phillips #1 screw under the stand mounting bracket.
Stand will easily pull off.
Turn monitor so that the screen is facing you.
Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
Lift the screen assembly from the plastic housing from the corners.
Remove the plastic buttons from the contacts
Remove the wire connecting the contacts to the screen assembly.
