HP pavilion 15-cs3073cl Disassembly
  1. HP pavilion 15-cs3073cl Disassembly, Remove front screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by removing the 3 screws on the bottom front of the laptop. A Phillips #00 works well here.
  2. HP pavilion 15-cs3073cl Disassembly, Remove hidden screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP pavilion 15-cs3073cl Disassembly, Remove hidden screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are 3 screws hidden under the rubber pads. Using a pry tool or something thin like a credit card to remove the glued on rubber pads you will find one screw on the left back and 2 under the right pad. Phillips #0 works well to remove these larger screws.
  3. HP pavilion 15-cs3073cl Disassembly, Pry the upper and lower body: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a thin pry bar or credit card push in between the upper and lower parts of the body and you'll hear a clicking sound as the tabs release the 2 pieces. Go all around the laptop until the bottom cover is completely off.
  4. HP pavilion 15-cs3073cl Disassembly, HDD removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you're upgrading the HDD remove the 2 screws on the exposed side and lift from that side. The other side is being held by 2 rubber nipples on a thin rubber strip that will bend as you pull the drive.
Josue Nolasco
crwdns2935283:001/13/17crwdne2935283:0
298 crwdns2915208:0crwdne2915208:0
Green Shield Technology crwdns2935289:0Green Shield Technologycrwdne2935289:0
Business
Good day,
Can we have the part number?
Cate Ledezma - crwdns2934203:0crwdne2934203:0
Hello, I’m not sure what part number you’re looking for. These instructions are for the disassembly of the laptop as stated in the title. Once disassembled, you can replace any parts you need.
Josue Nolasco - crwdns2934203:0crwdne2934203:0
This disassembly guide seems to only have the removal of the bottom cover and HDD, did I miss steps somewhere? Thanks!
John Doe - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 162
crwdns2942667:0crwdne2942667:0 7,811
