HP eStation Zeen Ground Wire Replacement
  1. HP eStation Zeen Ground Wire Replacement, Motherboard Ground Wire: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP eStation Zeen Ground Wire Replacement, Motherboard Ground Wire: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP eStation Zeen Ground Wire Replacement, Motherboard Ground Wire: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screw caps using a metal spudger.
    • Remove the four 6 mm screws using a Phillips #0 screwdriver.
  2. HP eStation Zeen Ground Wire Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP eStation Zeen Ground Wire Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP eStation Zeen Ground Wire Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic opening tool into the case seam and slide it along the edges.
    • Lift and remove the back panel from the device.
  3. HP eStation Zeen Ground Wire Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully disconnect the battery clip using small plastic spudger.
    • The clip is extremely fragile.
  4. HP eStation Zeen Ground Wire Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to disconnect the ground wire from motherboard terminal.
  5. HP eStation Zeen Ground Wire Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a soldering iron to remove the ground wire.
    • Avoid touching or heating the motherboard.
dalton hale
crwdns2935283:009/26/16crwdne2935283:0
508 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 16-4, Eyestone Fall 2016 crwdns2935289:0USF Tampa, Team 16-4, Eyestone Fall 2016crwdne2935289:0
USFT-EYESTONE-F16S16G4
crwdns2942667:0crwdne2942667:0 455
