By using this guide, you will easily be able to replace the keyboard and resume using your device.
Replacing the keyboard requires you to remove many components. Be sure to keep track of all supplies!
Remove the battery from the laptop.
Move the switch in the battery compartment.
Carefully flip up the keyboard panel.
Lift the retaining flap on the keyboard cable ZIF connector.
Carefully pull the ribbon cable from its socket on the motherboard.
First you need to unscrew 2 screws under the HDD cover
