If your wifi isn't working, it might just be a loose connection to your wireless card. Follow this guide to replace your wireless card.
            Slide the switch to the left until the release clicks.
            Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
            Pull up on the two plastic flaps on the hard drive enclosure to remove it.
            Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
            Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
            Slide the hard drive out of the enclosure to complete the removal process.
            Locate the wireless card and the two wires attached to it.
            Using a plastic spudger tool, carefully lift up on each wire connecting the card to unsnap the connectors.
            Locate the 2.5mm Phillips screw on the corner of the WLAN card and remove it using a Phillips #000 screwdriver.
            Upon removing the screw, the WLAN card will pop up. Keeping a natural angle, slide the card out of the slot.
            The card is now free from your computer.
