Many laptop issues trace back to a faulty RAM card. Luckily your memory is fairly easy to replace, just follow this guide!
Slide the switch to the left until the release clicks.
Remove the one 4mm Phillips screw from the RAM cover using a Phillips #00 screwdriver.
Remove the RAM cover to reveal the module's underneath.
Push the two metal tabs on the side of the RAM module outwards, towards the battery and CMOS compartments (up and down).
Once the module is released, gently pull the module upwards.
Repeat for the RAM module underneath the first one.
