HP ZBook Fury 15 G8 Thermal Paste Replacement
  1. HP ZBook Fury 15 G8 Thermal Paste Replacement, Opening the back panel.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP ZBook Fury 15 G8 Thermal Paste Replacement, Opening the back panel.: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP ZBook Fury 15 G8 Thermal Paste Replacement, Opening the back panel.: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 4 screws and slide the panel latch.
    • Slide the back panel to remove it.
  2. HP ZBook Fury 15 G8 Thermal Paste Replacement, Reaching the cooling system.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ZBook Fury 15 G8 Thermal Paste Replacement, Reaching the cooling system.: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all the screws that hold the plastic protective cover and also remove the battery.
    • Remove the 3 screws below the battery and also unplug the connectors of the LAN and WAN modules if you have.
    • After all of the above has been done, you can lift the plastic protective cover. Be sure to do it carefully!
  3. HP ZBook Fury 15 G8 Thermal Paste Replacement, Removing the cooling system.: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ZBook Fury 15 G8 Thermal Paste Replacement, Removing the cooling system.: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the display and fan cables and route them away.
    • Unscrew the fans and CPU pipes.
  4. HP ZBook Fury 15 G8 Thermal Paste Replacement, Changing the thermal paste.: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ZBook Fury 15 G8 Thermal Paste Replacement, Changing the thermal paste.: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU.
    • Don`t use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
  5. HP ZBook Fury 15 G8 Thermal Paste Replacement, Upgrading the RAM and SSD (Optional): crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you opened the back cover, it is a good idea to upgrade the RAM or the SSD if you want.
    • This laptops has 4 DIMM slots. 2 in the back and 2 behind the keyboard.
    • Also 2 m.2 SSD slots: 1 in the back and 1 behind the keyboard. As well as a full size laptop SSD in the back, behind the battery.
    • It is also recommended to use compressed air to remove any dust in the laptop and the fans.
Simeon Brankov
crwdns2935283:011/08/20crwdne2935283:0
7,399 crwdns2915208:0crwdne2915208:0
crwdns2935297:054crwdne2935297:0
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 168
crwdns2942667:0crwdne2942667:0 1,450
