HP ZBook 15u G2 Heatsink Replacement
  1. HP ZBook 15u G2 Heatsink Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the HP Zbook over and flip the switch at the top so the red part is visible.
  2. HP ZBook 15u G2 Heatsink Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the back cover down to remove it.
  3. HP ZBook 15u G2 Heatsink Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ZBook 15u G2 Heatsink Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the two switches on the top of the battery so the red is visible.
  4. HP ZBook 15u G2 Heatsink Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the plastic tab at the top of the battery up to lift the battery up and out of the device
  5. HP ZBook 15u G2 Heatsink Replacement, Heatsink: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ZBook 15u G2 Heatsink Replacement, Heatsink: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a torx 8 screwdriver to remove the 11 M2.5x5mm torx screws labeled M2.5x5.
    • Use a pair of tweezers to remove the rubber feet at the edges and corners of the laptop to reveal the other 8 torx screws and remove them as well
  6. HP ZBook 15u G2 Heatsink Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the five M2.0x2 mm screws beneath the battery.
  7. HP ZBook 15u G2 Heatsink Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 mm Phillips screws under the SD card slot on the left of the laptop.
    • Lift the plastic edges around the bottom of the laptop to remove the bottom plastic cover.
  8. HP ZBook 15u G2 Heatsink Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ZBook 15u G2 Heatsink Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the 2 silver Phillips screws on the fan assembly.
    • Remove the 6 Phillips screws at the left side of the heatsink assembly.
  9. HP ZBook 15u G2 Heatsink Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ZBook 15u G2 Heatsink Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, gently unplug the wire the connects the fan to the motherboard.
  10. HP ZBook 15u G2 Heatsink Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the heatsink assembly by the fan and lift it up to remove it.
    • Use computer duster to blow away and remove any dust and particles in and around the heatsink and fan assembly.
Kwasi Sarfo
crwdns2935283:003/13/23crwdne2935283:0
285 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-5, Petersen Spring 2023 crwdns2935289:0UMass Dartmouth, Team 3-5, Petersen Spring 2023crwdne2935289:0
UMASSD-PETERSEN-S23S3G5
crwdns2942667:0crwdne2942667:0 372
