HP ZBook 15 Screen Replacement
  1. HP ZBook 15 Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ZBook 15 Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Screen Replacement, Screen: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the laptop keyboard-side up.
    • Use tweezers to remove the adhesive covers for the screws.
  3. HP ZBook 15 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 6mm screws with a Phillips #0 screwdriver.
  4. HP ZBook 15 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ZBook 15 Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the bezel away from the screen.
    • Be sure to go one edge at a time! Do not pull hard on the corners as it may crack the bezel.
  5. HP ZBook 15 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3mm screws with a Phillips #0 screwdriver near the corners of the screen to remove the display.
    • Be careful not to confuse any screws. They are close together and you may remove the back cover instead of the display.
  6. HP ZBook 15 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ZBook 15 Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do not peel the tape from the side closest to the bottom of the screen panel! This may rip out the connector's wires.
    • Gently lower the screen and lay it face down on the keyboard.
    • Lift the corners of the tape closest to the top of the screen and peel toward the center carefully.
    • Slowly pull the tape away from the sides.
    • Lift the tape and disconnect the screen connector.
    • You can leave the tape stuck to the cable connector and still be able to remove it.
crwdns2935229:09crwdne2935229:0
Grant Terris
crwdns2935283:001/30/15crwdne2935283:0
2,864 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-43, Amido Winter 2015 crwdns2935289:0Cal Poly, Team 8-43, Amido Winter 2015crwdne2935289:0
CPSU-AMIDO-W15S8G43
Worked great! Only caution that I would add is that on one of the machines I took apart, the adhesive strip behind the bottom of the bezel stuck to the bezel and not the circuit board behind. I had to carefully slide my finger between the adhesive strip and the bezel to separate them. Once the bezel was removed, I was able to stick the adhesive back down. I think this laptop may have been exposed to some sort of liquid, so this may not be a common issue.
dwakefield - crwdns2934203:0crwdne2934203:0
My ZBook 15u g5 does not have any adhesive covers around the screen. How do I replace?
H B - crwdns2934203:0crwdne2934203:0
Hello can i replace my hd screen with another fhd one?
Mohand Almohands - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 83
crwdns2942667:0crwdne2942667:0 17,542
