HP ZBOOK 15 G5 Motherboard Replacement
  1. HP ZBOOK 15 G5 Motherboard Replacement, Opening the Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the bottom panel locking mechanism
    • Move the switch to the right to unlock and slide it in a downwards fashion
  2. HP ZBOOK 15 G5 Motherboard Replacement, Removing the Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery latches to the right to loosen the battery
    • Remove the battery and place it to the side
  3. HP ZBOOK 15 G5 Motherboard Replacement, Removing the Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP ZBOOK 15 G5 Motherboard Replacement, Removing the Keyboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the three keyboard screws on the bottom
    • While placing the laptop on it's side, push through the hole to release the keyboard
    • Once the latch releases, flip over the laptop and disconnect the three connectors as well
    • Place the keyboard to the side and flip the laptop over again
  4. HP ZBOOK 15 G5 Motherboard Replacement, Removing the Bottom Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove these screws with a T8 screwdriver
    • Remove these screws with a philips screwdriver
    • Once they are removed, carefully lift up the bottom case
  5. HP ZBOOK 15 G5 Motherboard Replacement, Removing SSD and LCD Connector Cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew SSD screw and slide the SSD out
    • Remove these screws and place the LCD connector cover to the side
    • Disconnect all of the motherboard connectors
  6. HP ZBOOK 15 G5 Motherboard Replacement, Removing the Fans: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew all of the screws on the fans (Keep in mind the screw don't come all of the way out)
    • Make sure to disconnect the fan connectors before removing it
  7. HP ZBOOK 15 G5 Motherboard Replacement, Removing the Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the motherboard screws
    • Make sure the SD card holder has been removed
    • Remove the motherboard and place it to the side
    • Place the new motherboard in and screw it into place
    • Screw in the fans and reconnect the motherboard cables
    • Reconnect the LCD connectors
    • Screw the bottom case back onto the laptop
    • Connect the battery and put the battery cover back into place
Once the repair had been done. Call the user and let them know their laptop is ready for pick-up
Ved Pitre
crwdns2935283:010/30/19crwdne2935283:0
1.092 crwdns2915208:0crwdne2915208:0
Is it necessary to remove the keyboard if one is just swapping out the fans?
Burtimus - crwdns2934203:0crwdne2934203:0
Answer: No, the keyboard does not have to be removed to swap out the fans .
My keyboard isn't work how i can remove it and clean it
Ayman Moftah - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 179
crwdns2942667:0crwdne2942667:0 6,731
