The CPU processor is the part of your device that handles multiple tasks and processes at once. If you need to replace the CPU of your HP Z2 Mini G3, follow this guide.
Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm you.
Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
Turn the device so the back-side of the device is facing you.
Slide and hold the latch in the direction of the engraved arrow (to the right).
While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
Rotate the device so the front side is facing you (the side with the power button) and locate the CPU fan.
Swing the fan upward, to a 90-degree angle.
Carefully disconnect the CPU fan by pulling out the wires from the motherboard.
Swing the fan back down and carefully unhook the CPU fan notches by pulling each tab away from the heat sink holes.
Swing the fan up again and pull it out.
Remove the 9mm Torx screw with a T15 Torx screwdriver to release the SSD assembly.
Lift the assembly upwards to remove it.
Pull the metal arm out from under the frame and lift it up. The frame should slide back from under the screw.
Lift the frame upward to gain access to the processor
Grip the processor on each side, carefully lifting it up.
