HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement
  1. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
  2. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
  3. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
  4. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
  5. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grasp the trigger with one hand while pushing against the outer wall of the shell.
    • Apply pressure, pulling the wall away from the trigger.
    • Remove the trigger starting from the freed edge.
    • The spring-rod assembly can easily come apart. Inserting the large end first during reassembly may make the process easier.
Clement Cheung
crwdns2935283:001/24/19crwdne2935283:0
643 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S18-G5, White Winter 2019 crwdns2935289:0Cal Poly, Team S18-G5, White Winter 2019crwdne2935289:0
CPSU-WHITE-W19S18G5
crwdns2942667:0crwdne2942667:0 1,738
